Driver not loading on Win7 x64
ui670
Post by ui670 »
Driver not loading on Win7 x64 after clean install.
when USB cable connected the blue light is on.
enclosed the log file
23:10:56.765: 3DxWare driver startup: 1/18/2011 23:10:56
23:10:56.767: 3DxWare Driver Version 6.12.0 : November 11, 2010
23:10:56.770: -quiet -- disabled
23:10:56.773: -shutdown -- disabled
23:10:56.776: -protocol -- none given. All protocols enabled.
23:10:56.779: -com -- Disabled, using spcware.ini file settings.
23:10:56.782: -dev -- Disabled, using spcware.ini settings.
23:10:56.785: -eps disabled sending each event.
23:10:56.788: -log enabled
23:10:56.791: -logLevel ffffffff
23:10:56.794: -logFile C:\Users\uri\AppData\Roaming\3Dconnexion\3DxWare\3DxWare.log
23:10:56.798: -searchWarnDlg enabled
23:10:56.801: -showGUI not enabled
23:10:56.805: -hideGUI not enabled
23:10:56.808: UdCtl: Attempting to find (ID=1033) 'English' locale in EN_US
23:10:56.811: UdCtl: Found resource DLL in C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\EN_US\3dxsrv.dll
23:10:56.817: UdCtl: initialization successful.
23:10:56.821: UdCtl: Attempting to open Any Device (-1) on USB.
23:10:56.825: UdCtl: Attempting to load device DLL: C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\UdDev\HIDDev.dll
23:10:56.829: UdCtl: Could not load device DLL HIDDev.dll. Error=0x1e7.
23:10:56.832: UdCtl: Unable to open Any Device (-1) on USB.
The most likely reason is an anti-virus programming blocking the driver from loading the dll. See if you can add the driver executable (3dxsrv.exe) to the exception list or similar feature.
Please let us know what you find and what anti-virus program you have installed.
ui670
Post by ui670 »
thanks
Ichanged antivirus program, now all is well.
