Error!!!!3DxRadialMenus
Zumba
Post by Zumba »
The cadmouse when giving two buttons for radial menus gives me the error 3DxRadialMenus stopped working, does anyone know how I can solve this?
Re: Error!!!!3DxRadialMenus
Driver version, in what CAX application you encountered such error? Attach some screenshots here, it's better for trouble-shooting analysis.
A driver reinstall may helps to solve your problem.
Zumba
Post by Zumba »
I can't add screenshot and I use it on NX cam.
Thank you
Zumba
Post by Zumba »
Lo estoy utilizando en NX cam, he reinstalado los controladores pero aun y todo no va.
Zumba
Post by Zumba »
Zumba wrote: ↑Wed Dec 16, 2020 1:52 am I can't add screenshot and I use it on NX cam.
Thank you
You can, look at here:
Zumba
Post by Zumba »
Ok, thank you
This is the error!!
Zumba wrote: ↑Wed Dec 16, 2020 5:04 am Ok, thank you
This is the error!!
Click for detail of the crash.
crash detail.png (76.48 KiB) Viewed 5517 times
By the way, what's your 3DxWare driver version?
You're on Windows 7, may be the last possible version for Windows 7 is 10.6.0:
https://3dconnexion.com/us/archived-drivers/
Zumba
Post by Zumba »
Windows 7
Maybe this driver version 10.6.3 is too new for your Windows 7. Try use v10.6.0 or even the uploaded 10.5.15:
https://we.tl/t-Ch5qUWVvVf
What's your NX version, NX 12?
Zumba
Post by Zumba »
Yes NX12, ok I will try another version.
Thank you
3Dconnexion is no longer testing on Windows 7 after Microsoft terminated support back in January. Driver stability on Windows 7 will degrade over time.
The last release tested on Windows 7 was version 10.6.4 which is still available from the driver archive. Older versions such 10.4.3 and 10.4.10 can also be found in the archive.
