Problem with 3D Connexion CadMouse in Solidworks
SWUser
Post by SWUser »
My problem is I can't rotate in Solidworks with the scroll wheel depressed anymore. It works in Mastercam, but not Solidworks. I have duel monitors, and if I have Solidworks open in a window and right click the other window, and move the curser over to Solidworks it will work as long as I hold down on it. If I let up on it, it no longer works, unless I click in the other window???
Anyone know what might be causing this? I'm using the latest drivers/software. This problem started about 3 years ago.
SWUser
Re: Problem with 3D Connexion CadMouse in Solidworks
Post by SWUser »
Correction to my post. (When I LEFT CLICK in the other window) Another strange thing I just tried. I have both Solidworks 2019 and 2020 installed. I opened 2019 in one window, and 2020 in the other window. The left click "trick" didn't work with that.
Would also like to add, I am using a SpacePilot Pro. Also, if I uncheck the 3D Connexion Add-in for Solidworks, and close, then reopen I get an error message to run Solidworks Rx
In USA, the starting price of a SOLIDWORKS CAD standard licence is $3995 with an annual maintenance fee of $1295, the prices of different SOLIDWORKS packages' prices in other countries are slightly higher than that in USA, since you stated that you can upgrade to latest version of SOLIDWORKS software application, I naturally assume that you or your employer can afford to invest on software licensing cost, why not invest on a left-hand SpaceMouse 3D navigation device to support fluid 3D spatial rotation?
SWUser
Post by SWUser »
luping wrote: ↑Mon Apr 25, 2022 9:19 pm In USA, the starting price of a SOLIDWORKS CAD standard licence is $3995 with an annual maintenance fee of $1295, the prices of different SOLIDWORKS packages' prices in other countries are slightly higher than that in USA, since you stated that you can upgrade to latest version of SOLIDWORKS software application, I naturally assume that you or your employer can afford to invest on software licensing cost, why not invest on a left-hand SpaceMouse 3D navigation device to support fluid 3D spatial rotation?
Where did I say I could upgrade to latest version of Solidworks Software? I meant that I have all the latest drivers for the 3D Connexion devices. And, in my 2nd post said I have a SpacePilot Pro for fluid 3D spatial rotation.
Thanks for your reply. Any more help out there?
SWUser wrote: ↑Tue Apr 26, 2022 2:15 pm
Your second post appeared later than my reply, may be due to new forum member post reply approval process.
As for your issue regarding rotation with CadMouse in SOLIDWORKS, use SpaceMouse/SpacePilot Pro to rotate the 3D model. The CadMouse is designed to pan/zoom in 2D drawing, 3D model, scroll in office applications like spreadsheet application, word processing application. There's no mention of 3D rotation in the product specification/introduction of CadMouse, the demoed videos of CadMouse only shows pan/zoom in SOLIDWORKS, along with 3D rotation with left-hand SpaceMouse Pro.
CadMouse intro scroll.jpg (69.43 KiB) Viewed 4306 times
CadMouse intro zoom.jpg (100.57 KiB) Viewed 4306 times
SWUser
Post by SWUser »
luping,
I would like to thank you for your replies 1st and foremost. But, if this mouse wasn't designed to rotate, why is it FULLY PROGAMABLE?
Screenshot 2022-05-01 131036.jpg (73.1 KiB) Viewed 4224 times
You have though reminded me that the mouse has a center button that by default is set to rotate! So, I will use that when my left hand is not using the Space Pilot Pro. :roll:
Good Day to all.
