The 3d device in solidworks2021 is not responding
Hello,The 3d device in solidworks2021 is not responding,驱动版本10.8.7
Re: The 3d device in solidworks2021 is not responding
Which device model?
Make sure you have activated the 3Dconnexion plug-in in the SOLIDWORKS plug-in manager.
Hello, the device model is SpaceMouse Wireless. When installing the driver, I checked the SOLIDWORKS plug-in. The 3D plug-in in SOLIDWORKS was also started, but it did not respond and could not be used. It works in 3Dconnexion Viewer, but does not work in Solidworks2021 .
Request 3Dconnexion official support from here:
https://3dconnexion.com/cn/support/
Hello, I now have a new question. The driver conflicts with the software I use Autodesk AutoCAD. As long as the driver is on, Autodesk AutoCAD will not load out, opening is very slow.
Driver version 10.8.3; Autodesk AutoCAD 2014
Hi bbblll
Firstly I would recommend switching to our newest driver which is available to download on our website.
Does the latest driver 10.9.1 support Autodesk AutoCAD 2014? My software version is 2014.
I was unable to install the 10.9.1 driver because the latest driver requires Windows 10 2004(20H1) and later.
My computer system does not support it!
10.8.14的驱动程序支持Autodesk AutoCAD 2014吗?我的软件版本是2014。
- Attachments
- QQ20241011-100757.png (151.21 KiB) Viewed 4072 times
Try 3DxWare v10.6.9, it is digitally signed on July 24, 2020.
