AutoCAD circle shortcut always demands radius
Biscain
Post by Biscain »
I programmed the second shortcut button on the numpad to create a circle based on a centerpoint and the diameter but I always have to enter the radius. Switching the shortcut to a button on the keyboard didnt help.
On my private laptop the shortcut works flawless; it only happens at my work station. Both have installed the same AutoCAD version.
I just got the 3DConnexion equippment so I'm not sure if this is a ACAD problem/setting or based on the keyboard driver. If anyone knows how to fix this issue I'd highly appreciate some help.
Thanks in advance,
Biscain
Biscain
Re: AutoCAD circle shortcut always demands radius
Post by Biscain »
Update:
Checked on my laptop again and can't get it to work there as well.
Export your 3Dxware settings in your workstation, and copy the resultant file to your private laptop and import it to your 3DxWare driver, if you use the same model of 3Dconnexion equipment for the workstation and private laptop. You may have to backup all the 3DxWare settings/configuration of your private laptop at first if you regret such change. There's the 'Export Button Configuration only' option for extra notice.
'Reset all settings' may also be another option.
