Hello people
I'm getting this error "Unable to load an 3Dxservice.dll resource DLL" for some reason I've tryed to clean up the files update driver everything else but still doesn't work. I didn't have those problems on Windows 10, but when I moved do 11 I got this.
Anyone got a solution for this issue?
Best regards!
Re: Unable to load an 3Dxservice.dll resource DLL
You should have at least an "en-US" directory under the <3DxWinCore> installation directory. That directory should have a 3DxService.dll file in it.
The <3DxWinCore> installation directory is normally:
C:\Program Files\3Dconnexion\3DxWare\3DxWinCore
but you may have changed that during the installation process.
The requested directory is related to your language settings. Which language is your system using?
If the file isn't there, let us know.
Hello Moderator
Yes I found the "en-US" directory in this path location, that's the place where I installed the application too. Also I've found that 3DxService.dll folder in it. But still when I click 3DConnexion app it gives me same error.
I've attached some screenshots.
- Attachments
- 3.png (4.69 KiB) Viewed 2657 times
- 2.png (41.66 KiB) Viewed 2657 times
- 1.png (44.17 KiB) Viewed 2657 times
Your Windows language is set to Croatian?
I'd like to see your %localappdata%\3Dconnexion\3DxWare\3DxService.l* files, if you have any.
If you don't have any, I'll need to tell you how to enable them.
I assume you have never been able to run the driver.
