Import/Export Settings
PC_Eire
Post by PC_Eire »
I have upgraded from a SpaceMouse Pro Wireless to a SpaceMouse Pro Wireless (Bluetooth Edition).
I exported all settings from the older device to a .3dxz file.
I tried importing these settings to the new device but it isn't picking them up.
Is this a bug/issue or do I have to start all over again with this new device?
skmiec
Re: Import/Export Settings
Post by skmiec »
hi PC_Eire
Which version of the driver do you use?
Best regards
Stanisław
PC_Eire
Post by PC_Eire »
10.8.21.3755
What was your old 3DxWare version (that you exported from)?
PC_Eire
Post by PC_Eire »
The same version
No, you don't need to redo everything for the new device.
There are a couple of ways of addressing it.
How many files have you imported?
Are you actively using both devices?
I've fixed this import behavior for the next release.
jwick wrote: Tue Jul 02, 2024 4:45 am No, you don't need to redo everything for the new device.
So when will the next minor update be available?
luping wrote: Tue Jul 02, 2024 5:51 am
Can't say...
Was there something particular you were looking for luping?
jwick wrote: Tue Jul 02, 2024 6:18 am
Can't say...
I periodically export the 3DxWare settings. In case I need to restore some specific setting after I changed the key button mapping, I'll import the 3dxz file. Thus the need to ensure there's no unexpected bug/glitch in the import behaviour.
In light of the unspecified release date, I'll just keep the current 3DxWare settings unchanged, and wait for the next minor update. :D
PC_Eire
Post by PC_Eire »
I got in contact with 3D Connexion support who told me I had to create all my settings again for the new device just this week... so I did and it was painful.
Like I said, extremely disappointing miss as right now the settings are not transferable. It has put my colleagues off purchasing the updated version of the spacemouse as a result.
PC_Eire wrote: Tue Jul 02, 2024 11:47 pm
Oh, boy, don't do so, the 3Dconnexion hardware is good for your health. You only need to create the button mapping once for the computer and backup the settings by exporting them.
PC_Eire,
That's too bad that you wasted so much time. Tell your colleagues to contact me first :)
Do you continue to use both devices? Or have you completely switched to the new BT device?
E.g., sometimes people take the old device home, to use it there.
PC_Eire
Post by PC_Eire »
jwick wrote: Wed Jul 03, 2024 4:26 am PC_Eire,
Exactly that, I've brought the old one home.
Will you be using the same machine with both devices? Or, is that a different machine at home.
I'm trying to determine the need for an ongoing sharing of the settings between the two devices.
ATM, changes are not shared between the "similar" devices.
PC_Eire
Post by PC_Eire »
jwick wrote: Wed Jul 03, 2024 6:19 am Will you be using the same machine with both devices? Or, is that a different machine at home.
Same laptop with both devices
