Macro Maker 10.9.3 - Awesome but missing key feature?
dumbweighter2
Post by dumbweighter2 »
Good Morning | Afternoon | Evening
After 6 or so years of blissful use, I upgraded from 10.6.8 to 10.9.3. The impetus for such a dramatic move was seeing the latest macro creator on another user's machine. Holy crap! Such upgrade! I like that you can build your macro step by step. But!
I realized yesterday that it's missing a key feature. With this feature, it would be perfect. Without it, it is still required to edit XMLs to build even some simple macros by hand. And in this New Age, instead of being able to record a macro and then edit it, it appears that the entire macro must be built in xml.
The feature that the latest macro maker is missing is the record feature! Being able to build step by step is AMAZING progress, but i can't seem to be able to insert a KeyPress or a KeyRelease for doing something as simple as ctrl + pagedown. I wound up going back old school to make this simple macro.
I posit that with the introduction of a record function to join Command, Text, and Delay functions would make this a fully developed macro maker, and I can forget all about <KeyPress>E0</KeyPress>. It could also be that I'm missing something! Am I missing something??!
| Night,
Dumbweighter
dumbweighter2
Re: Macro Maker 10.9.3 - Awesome but missing key feature?
Ah, can't figure out how to edit my initial post, but it appears that my example was not a good one.. Turns out, ctrl+pagedown does work nicely. What i did find missing is a way to, if one wished to, hold shift and press any number of keys, or anything like that. Might be of limited usage but i still feel that the macro maker would be perfect if it had this feature.
dumbweighter2
Also, i'm considering reporting my own post due to slow response to having it approved lol not sure how else to make it go faster!
Frownd
Post by Frownd »
dumbweighter2 wrote: Fri Mar 14, 2025 6:54 am Good Morning | Afternoon | Evening
| Night,
Dumbweighter
The new macro builder has improved, but still doesn't have a real record feature.
You still edit XML manually for key combos like Ctrl + PageDown.
