Enterprise mouse settings not saving
Iamthehuman
Post by Iamthehuman »
Hello -
New user. When I restart my computer for any reason, the settings I change in the Mac settings do not save. I found this out after spending an hour or so setting up my own shortcuts, macros, radial menus, etc. when I restarted, all gone.
I recreated them - then saved them manually using the export function. I restarted as a test and they are gone again. But I’m able to import the settings. While this is a fix of sorts, this feels like it shouldn’t be the case.
Am I doing something wrong? I’m on a Mac Studio, sequoia. Connected directly.
skmiec
Re: Enterprise mouse settings not saving
Post by skmiec »
Hi Iamthehuman,
For what application do you set your custom settings?
Iamthehuman
I create the settings in the official settings under OSX System settings, then 3D Connexion at the bottom. No third party use.
Screenshot 2026-01-23 at 9.08.13 AM.png (231.64 KiB) Viewed 833 times
skmiec
Post by skmiec »
Hi
Thank you for information. I wanted to ask what application was selected under configure drop-down? Was it Any application?
Iamthehuman
I don’t think that should matter, should it?
I made changes in the autodesk selection for fusion. When I restart my computer, those changes are no longer present in the autodesk selection. I have to reload my settings. The work around works, but it feels like it should just automatically load with your last used settings, shouldn’t it?
resultshoe
Post by resultshoe »
Iamthehuman wrote: ↑Thu Jan 29, 2026 4:44 pm I don’t think that should matter, should it?
I agree, that does seem like expected behavior. If the selection settings are meant to persist, having to reload them after every restart is inconvenient. Hopefully there’s a setting or preference that can save them automatically.
