Right button & Zoom do not work simultaneously
Sagataev
Post by Sagataev »
In the programs, the right mouse button (rotate) and the zoom function (Forward/Back or Up/Down in the settings) do not work simultaneously on the SpaceMouse Wireless 3DX-600060 and SpaceMouse Enterprise 3DX-600061. In other words, I want to rotate an object and simultaneously zoom in or out. I have a wired version of the SpaceMouse Compact, and it works perfectly. It is slightly older than the ones that do not work. Is it possible that the old firmware works while the new firmware does not? Can I roll back or update the firmware on new controllers?
skmiec
Re: Right button & Zoom do not work simultaneously
Post by skmiec »
Hi Sagataev,
What programs do you use and wich driver version?
Sagataev
Post by Sagataev »
Hi skmiec,
This is mostly Exocad. Version 3.2 build 9036.
3DxWare 10.9.5.693
3DxWinCore 17.9.5.21635
SpaceMouse Compact FW: 4.37
SpaceMouse Wireless only has PID in the program/
Universal Reciever FW: 1.11
skmiec
Post by skmiec »
I recommend you to update your 3DxWare driver. You can find it here.
Also maybe you turned on the dominant option in 3Dconnexion advanced settings for your SpaceMouse Enterprise/SpaceMouse Wireless
floorum post.png (6.41 KiB) Viewed 1150 times
Sagataev
Post by Sagataev »
I installed it, but it didn't help.
skmiec
Post by skmiec »
Hi Sagataev,
We have reported this issue in our internal system.
We will contact Exocad in order to take the next steps.
Sagataev
Post by Sagataev »
Apparently, this will take a long time. Can you tell me how to find a 3DX-600053 controller with the same FW: 4.37? Is the 3DX-700059 option suitable for me?
skmiec
Post by skmiec »
Firmware of the controller can be upgraded using specific tool. You can enroll to customer service for such one.
Sagataev
Post by Sagataev »
Hello, have you received a response from Exocad?
