Zbrush 2024.2
Arsen
Zbrush 2024.2
Post by Arsen »
Spacemouse navigation is laggy in the new version of Zbrush, the older versions have no issues, because Zbrush performs adaptive viewport degradation, while the new one doesn't
https://imgur.com/a/MnwE7Or The first gif compares different versions, the second one I compare my model when using mouse navigation vs Spacemouse navigation
skmiec
Re: Zbrush 2024.2
Post by skmiec »
Hi Arsen thanks for pointing this out.
We are on it, it's recorded in our managment system.
We will correct it.
Arsen
Re: Zbrush 2024.2
Post by Arsen »
Thank you for the quick reply!
taj
Re: Zbrush 2024.2
Post by taj »
any word on when this update will be released? Its unusable without this fix in zbrush.
Arsen
Re: Zbrush 2024.2
Post by Arsen »
Still unusable
kgryzka
Re: Zbrush 2024.2
Post by kgryzka »
I have same problems during newest ZBrush. Navigation with heavy models is very complicated.
luping
Re: Zbrush 2024.2
Post by luping »
kgryzka wrote: Mon Aug 26, 2024 4:26 am I have same problems during newest ZBrush. Navigation with heavy models is very complicated.
What's the graphics card being used? Nvidia RTX 5000 Ada or even RTX 6000 Ada?
kgryzka
Re: Zbrush 2024.2
Post by kgryzka »
This has no impact on the software. ZBrush doesn't use the graphics card during rendering in the viewport. The issue exists because the 3DConnexion software is missing the QTrans operator in ZBrush. I described this in detail in my post here: https://forum.3dconnexion.com/viewtopic.php?t=56317
As far as I know, the support team is aware of the issue and is working to fix it. However, I'm becoming concerned since we've been waiting for this fix for a few months now.
Hello 3DConnexion, could you provide us with information on when you plan to release this fix? Thank you very much!
unintendexp
Re: Zbrush 2024.2
Post by unintendexp »
I have same problem. Its really annoying. It's been talked about here for a long time. I don't understand how they haven't done it yet.
kgryzka
Re: Zbrush 2024.2
Post by kgryzka »
skmiec wrote: Fri Mar 15, 2024 1:30 am Hi Arsen thanks for pointing this out.
We will correct it.
@skmiec Could you provide us with any information on when this will be corrected?
unintendexp
Re: Zbrush 2024.2
We will correct it.
WHEN!! please I really need this update very urgent.
Liftmodez
Re: Zbrush 2024.2
Post by Liftmodez »
wow that's a bummer. I almost bought a few of the spacemouse pro till i found out it doesn't support the latest Zbrush. Chatgpt led me here, btw. Does anyone know if there is an alternative that does work currently?
kgryzka
Re: Zbrush 2024.2
Post by kgryzka »
Hello. Could you provide us any information, when you plan to fix this issue?
luping
Re: Zbrush 2024.2
Post by luping »
kgryzka wrote: Wed Sep 25, 2024 2:25 am Hello. Could you provide us any information, when you plan to fix this issue?
v10.9.1 is out.
skmiec
Re: Zbrush 2024.2
Post by skmiec »
Hello kgryzka unintendexp and other forum users.
After reviewing the issue, it turned out that the problem appears to be in the application and 3Dconnexion cannot address it.
