Zbrush 2024.2
Zbrush 2024.2
Spacemouse navigation is laggy in the new version of Zbrush, the older versions have no issues, because Zbrush performs adaptive viewport degradation, while the new one doesn't
https://imgur.com/a/MnwE7Or The first gif compares different versions, the second one I compare my model when using mouse navigation vs Spacemouse navigation
Re: Zbrush 2024.2
Hi Arsen thanks for pointing this out.
We are on it, it's recorded in our managment system.
We will correct it.
We will correct it.
Re: Zbrush 2024.2
Thank you for the quick reply!
Re: Zbrush 2024.2
any word on when this update will be released? Its unusable without this fix in zbrush.
Re: Zbrush 2024.2
I have same problems during newest ZBrush. Navigation with heavy models is very complicated.
Re: Zbrush 2024.2
This has no impact on the software. ZBrush doesn't use the graphics card during rendering in the viewport. The issue exists because the 3DConnexion software is missing the QTrans operator in ZBrush. I described this in detail in my post here: https://forum.3dconnexion.com/viewtopic.php?t=56317
As far as I know, the support team is aware of the issue and is working to fix it. However, I'm becoming concerned since we've been waiting for this fix for a few months now.
Hello 3DConnexion, could you provide us with information on when you plan to release this fix? Thank you very much!
Re: Zbrush 2024.2
I have same problem. Its really annoying. It's been talked about here for a long time. I don't understand how they haven't done it yet.
Re: Zbrush 2024.2
wow that's a bummer. I almost bought a few of the spacemouse pro till i found out it doesn't support the latest Zbrush. Chatgpt led me here, btw. Does anyone know if there is an alternative that does work currently?
Re: Zbrush 2024.2
Hello. Could you provide us any information, when you plan to fix this issue?
Re: Zbrush 2024.2
Hello kgryzka unintendexp and other forum users.
After reviewing the issue, it turned out that the problem appears to be in the application and 3Dconnexion cannot address it.
