Problems
Rillee
Problems
Post by Rillee »
Im having problem with my space navigator. It will only start 2/5 of times. When it happens i have to unplug it and plug it in and start the drivers manual. Whats wrong with my hardware?
rstadie
Post by rstadie »
Hi Rillee,
This could be caused by several things (hardware/software). Please contact Technical Support - they will be able to find out what is going wrong.
Robert Stadie
Rillee
Post by Rillee »
why cant i get help here?
rstadie
Post by rstadie »
It may be that your device needs to be replaced. Is the SpaceNavigator recognized by windows while it does not work?
Robert Stadie
Rillee
Post by Rillee »
no i cant find it in the device manager, put if unplug it and start the driver it works
Rillee
Post by Rillee »
I purchased it 2007-04-01 have you changed something in the hardware in space navigator since then? Our is my just "broken"?
rstadie
Post by rstadie »
I am not sure what is causing this trouble but I would guess your device needs to be replaced.
Robert Stadie
Rillee
Post by Rillee »
The strange thing is that it works on my second computer.
rstadie
Post by rstadie »
Can you locate the SpaceNavigator in device manager while it works?
Robert Stadie
Rillee
Post by Rillee »
Yes
rstadie
Post by rstadie »
It seems as the USB port of your computer or your SpaceNavigator is running at the edge of specifications. As all other USB devices work without problems on your computer it seems as this specific unit is causing the trouble.
Robert Stadie
Rillee
Post by Rillee »
Yes im running a others usb devices with no problem, usb-memory, gps receiver and touch screen. I have also tried running the spacenavigator alone but it didn't help. There is no way to test if its my usb on my computer that is running at the edge of specifications? I dont want to send back the spacenavigator if there no error with it.
rstadie
Post by rstadie »
What happens if you use a powered USB-Hub?
Robert Stadie
Rillee
Post by Rillee »
This is a carpc so i don't have powered usb. But does the spacenavigator use more than 500mA?
Hi Rillee,
No. Some USB ports, thought, may supply less than than required by the device.
Since the issue seems to "follow" your SpaceNavigator, you should -- as rstadie suggested -- contact one of our Customer Service representatives. They will be able to replace it. Contact are available here.
