cadmouse gesture button no work for CATIA, CREO......
wug
Post by wug »
hi,
The dialogue appears " the exception unknown software exception (0xe0434352) occurred in the application at location 0xfcc4a06d"
thank you.
Re: cadmouse gesture button no work for CATIA, CREO......
Hello wug,
which driver version do you have installed?
What is your operating system?
What name is in the title of the dialog box?
Can you please remove the existing configuration as described in this FAQ? Please make a backup of the files so that you can send them to us in case this helps. Thanks.
wug
Post by wug »
Hi, UtaSH
Thank you very much for your reply.
Unfortunately it still doesn't work after completing following your instruction.
The driver version is 3DxWare64_v10-3-0_r2161
Operating system is Windows 7 Enterprise Service Pack 1, 64-bit.
The title is "3dxpiemenus.exe - Application Error".
I also upload attachment.
Thank you again
BR
Wu Guan
configuration.7z
configuration file
(8.42 KiB) Downloaded 302 times
wug
Post by wug »
Another attachment.
I hope it is helpful to you.
BR
Wu Guan
3Dconnexion.bak.7z
configuration
(9.77 KiB) Downloaded 307 times
Hi Wu Guan,
can you please post the screenshot of the error that you get?
I assume that you get the error only if you are using a button where a Radial Menu is mapped to?
wug
Post by wug »
For your information.
Thank you very much for your done.
BR
Wu Guan
screen shot
screen shot
2016-04-05 13_52_23-.png (164.36 KiB) Viewed 7605 times
Hello Wu Guan,
does this happen with Catia only or do you see the same happen if you launch a Radial Menu in another application, for example in Excel or Outlook or the 3Dconnexion Viewer?
wug
Post by wug »
Unfortunately it happened in any application, for example in CATIA, CREO, and so on.
wug
Post by wug »
It was strange that button returned to work in this morning when I started computer.
Computer updated automatically on the weekends probably.
thank you all the same for your work.
Best Regards
Wu Guan
2016-04-11 09_31_20-CATIA V5R20SP6 AVL 64 - [Part2].png (30.67 KiB) Viewed 7542 times
